Wat je nodig hebt
Turn the power off and turn the netbook upside down.
Slide both battery catches together to release the battery.
Slide the battery out.
Locate the memory compartment.
Using a Plastic Opening Tools, remove the screw rubber cover.
Remove the screw.
Remove the screws as necessary.
For top cover removing, only remove the 2 bottom screws.
The one short screw paterns to uper left screw hole directly on the PCB.
Use a Plastic Opening Tools to release the top cover.
Start from the left side.
Go around on the bottom
Finish with the right side.
excellent guide. but be careful - it's very easy to broke narrow plastic clip :(
Remove the keyboard 4 screws on the bottom.
Use a Plastic Opening Tools to release the keyboard clips on the left and right side.
Peel off the protective tape at the bottom left corner.
Peel off the warranty void at the bottom right corner and remove the screw below.
Remove the 6 other screws.
Remove the four Phillips #00 screws from the hard drive caddy.
Peel off any tape covering the hard drive, there is no need to remove it entirely.
25 andere personen hebben deze handleiding voltooid.
7 opmerkingen
I've just upgraded my 1215N HDD using this guide. This is very good step by step guide. A WIndows 10 Pro install managed to wreck the pre-installed HDD.
Like Tolidano , I just used a normal flat head screwdriver and a Philips screwdriver to carry out the HDD swap. I'm now in the process of installing Windows 10 Pro on to the new HDD.
I also had to remove the two (tiny, but phillips #00) screws from the battery compartment.
I actually went further and removed the motherboard to clean the fan. It wasn't too hard thanks to your guide!
I, too had to remove the battery compartment screws. Other than that, and that I couldn’t get the keyboard cable out, the replacement went flawlessly.
While there is a fairly long list of tools listed here, I was able to complete the entire guide using only a 3/64" flathead mini screwdriver (the kind you get for $0.99). I replaced the stock 500GB 5400RPM drive with the updated 7200RPM slim drive of the same line with no issues. The BIOS picked it up immediately, and I need only reinstall an OS.
Tolidano - Antwoord
Missing step: remove the two screws under the battery, otherwise the keyboard won’t come off
Andrea Borgia - Antwoord
