Ga door naar hoofdinhoud
Asus Eee PC 1008ha Cooling Fan Replacement
Wat je nodig hebt
  1. Asus Eee PC 1008ha Cooling Fan Replacement, Battery: stap 1, afbeelding 1 van 1
    • Using the plastic opening tool, carefully pry the top panel from the base.
  2. Asus Eee PC 1008ha Cooling Fan Replacement: stap 2, afbeelding 1 van 3 Asus Eee PC 1008ha Cooling Fan Replacement: stap 2, afbeelding 2 van 3 Asus Eee PC 1008ha Cooling Fan Replacement: stap 2, afbeelding 3 van 3
    • Lift the side of the keyboard.
    • Disconnect the attached ribbon located underneath the keyboard.
    • Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
  3. Asus Eee PC 1008ha Cooling Fan Replacement: stap 3, afbeelding 1 van 2 Asus Eee PC 1008ha Cooling Fan Replacement: stap 3, afbeelding 2 van 2
    • Use your fingers to lift the battery and gently disconnect the wires from the base.
  4. Asus Eee PC 1008ha Cooling Fan Replacement, Cooling Fan: stap 4, afbeelding 1 van 3 Asus Eee PC 1008ha Cooling Fan Replacement, Cooling Fan: stap 4, afbeelding 2 van 3 Asus Eee PC 1008ha Cooling Fan Replacement, Cooling Fan: stap 4, afbeelding 3 van 3
    • Use the Phillips #0 screwdriver to remove the two 2mm screws from the copper heat sink. These are found on the left side of the device.
    • Make sure to remove the adhesive tape from the top of the heat sink.
  5. Asus Eee PC 1008ha Cooling Fan Replacement: stap 5, afbeelding 1 van 2 Asus Eee PC 1008ha Cooling Fan Replacement: stap 5, afbeelding 2 van 2
    • Remove the small white connector attached to the fan. Make sure to carefully pull from the white connector. Do not pull the connecting wires, as this can cause damage to the component.
    • Replace with new cooling fan!
Conclusie
To reassemble your device, follow these instructions in reverse order. If your device is still having issues after replacing the cooling fan, ensure the device is powered off and carefully follow this guide from the beginning; you may have misplaced something. We hope this guide has served as a helpful resource in replacing your Asus Eee PC 1008ha cooling fan!
Michael Dooley
138 Reputatie
3 handleidingen geschreven
Cal Poly, Team 21-52, Johann Spring 2013 Lid van Cal Poly, Team 21-52, Johann Spring 2013
CPSU-JOHANN-S13S21G52
4 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 1,727
