Inleiding
The wifi card is located under the trackpad of the laptop. Before starting the guide, make sure the laptop's charger is not plugged in.
Warning: This guide causes warranty of laptop to be voided.
Wat je nodig hebt
Start by placing the laptop upside-down on a flat surface.
Find the two clips on the back portion of the laptop.
Face the laptop so the 4 silver "clips" along the middle of the battery cartridge are in front of you.
Turn the laptop right side up and lift the lid.
Insert the flat end of the spudger into the small gap between the top of the keyboard and the plastic of the laptop.
Using the spudger as leverage, lift the keyboard up from the rest of the laptop.
Run the spudger across the seam until the entire top edge is exposed. The two sides of the keyboard should also pop up in this process.
Turn laptop upside down.
Find and unscrew the 5.5 mm Phillips #1 screw on the ram cover.
4 andere personen hebben deze handleiding voltooid.
