Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Inleiding
The battery is located on the bottom of the laptop. Before starting the guide, make sure the laptop's charger is not plugged in. No tools are needed for this guide.
  1. Start by placing the laptop upside-down on a flat surface.
    • Start by placing the laptop upside-down on a flat surface.
    • Find the two clips on the back portion of the laptop.
  2. Using your finger, push the clip labeled with a "1" on the laptop from the lock position to unlock position.
    • Using your finger, push the clip labeled with a "1" on the laptop from the lock position to unlock position.
    • This clip will hold itself, so after you move it to the unlock position you can remove your finger.
  3. Using your finger, push and hold the pin indicated by a "2" on the laptop from the lock to unlock position. While holding this pin in the unlock position, use your other hand to pull the battery horizontally away from the laptop.
    • Using your finger, push and hold the pin indicated by a "2" on the laptop from the lock to unlock position.
    • While holding this pin in the unlock position, use your other hand to pull the battery horizontally away from the laptop.
    • When the pins on the battery that reach towards the laptop are away from the laptop, you can release the "2" clip.
  4. Using both hands, pull the battery horizontally away from the laptop.
    • Using both hands, pull the battery horizontally away from the laptop.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Aaron Arenas
691 Reputatie
5 handleidingen geschreven
Cal Poly, Team 13-32, Maness Spring 2014 Lid van Cal Poly, Team 13-32, Maness Spring 2014
CPSU-MANESS-S14S13G32
5 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 1,069
