Ga door naar hoofdinhoud
Asus Eee PC 1005HA Keyboard Replacement
Wat je nodig hebt
  1. Asus Eee PC 1005HA Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Lay the laptop upside down.
    • Locate the two battery lock tabs.
  2. Asus Eee PC 1005HA Keyboard Replacement: stap 2, afbeelding 1 van 3 Asus Eee PC 1005HA Keyboard Replacement: stap 2, afbeelding 2 van 3 Asus Eee PC 1005HA Keyboard Replacement: stap 2, afbeelding 3 van 3
    • Slide the tabs outward to unlock the battery.
    • The left tab will remain unlocked, while the right tab must be held.
    • Holding the right tab open, slide the battery out of the laptop.
  3. Asus Eee PC 1005HA Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 2 Asus Eee PC 1005HA Keyboard Replacement, Keyboard: stap 3, afbeelding 2 van 2
    • Use a plastic opening tool to pull up the four metal latches in the battery cavity that is located on the bottom of the laptop.
    • Do not apply too much pressure. The latches can not be removed and will bend if forced.
  4. Asus Eee PC 1005HA Keyboard Replacement: stap 4, afbeelding 1 van 3 Asus Eee PC 1005HA Keyboard Replacement: stap 4, afbeelding 2 van 3 Asus Eee PC 1005HA Keyboard Replacement: stap 4, afbeelding 3 van 3
    • Flip the laptop over, and open the display.
    • Use a plastic opening tool to lift the edge of the keyboard that is nearest to the screen.
    • Gently lift the keyboard and slide it toward the screen.
    • Do not remove the keyboard completely. This can damage the ribbon cable connecting the underside of the keyboard to the laptop.
  5. Asus Eee PC 1005HA Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Use a spudger tool to release the tabs on the ribbon cable ZIF connector that is attached to the underside of the keyboard.
    • Depending on the model, the tabs on this ZIF connector will either flip up toward the display or push out toward the display.
    • Once the ZIF connector tabs have been released, remove the keyboard.
Conclusie
12 andere personen hebben deze handleiding voltooid.
Chris Beichler
579 Reputatie
2 handleidingen geschreven
Cal Poly, Team 11-22, Maness Winter 2012 Lid van Cal Poly, Team 11-22, Maness Winter 2012
CPSU-MANESS-W12S11G22
3 Leden
12 handleidingen geschreven
Één opmerking
after i upgrade my bios keyboard stop working . but external keyboard working fine.. plz help
anytimerabin - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 23,413
