Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Lay the laptop upside down.
Locate the two battery lock tabs.
Slide the tabs outward to unlock the battery.
Holding the right tab open, slide the battery out of the laptop.
Use a plastic opening tool to pull up the four metal latches in the battery cavity that is located on the bottom of the laptop.
Flip the laptop over, and open the display.
Use a plastic opening tool to lift the edge of the keyboard that is nearest to the screen.
Gently lift the keyboard and slide it toward the screen.
Use a spudger tool to release the tabs on the ribbon cable ZIF connector that is attached to the underside of the keyboard.
Once the ZIF connector tabs have been released, remove the keyboard.
Detach the ribbon cable that connects the SD card module and the motherboard by lifting the black clips using the plastic opening tool.
Detach the Bluetooth wire located below the fan by gently pulling it upward.
Detach the black structure connected to the input cables in the top right center of the motherboard by pulling them to the right, away from the fan.
Remove the three 5.5 mm screws holding the motherboard to the motherboard plastic frame.
Remove the four 5.5 mm screws surrounding the fan.
Disconnect the cable attaching the motherboard to the fan.
Remove two 5.5 mm screws holding the fan and the brass frame to the motherboard.
4 andere personen hebben deze handleiding voltooid.
