Inleiding
In this moderate replacement guide, you will be instructed on the process of removing the back plate and making the necessary adjustments to ensure the device's power is not on before removing and replacing the speaker system.
Wat je nodig hebt
Remove three of the rubber feet on the bottom cover with a plastic or metal spudger.
To reassemble your device, replace the broken or faulty speaker system with a new speaker system and follow these instructions in reverse order.
