Ga door naar hoofdinhoud
Asus Chromebook Flip C100 Lower Case Replacement
Wat je nodig hebt
  1. Asus Chromebook Flip C100 Lower Case Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • Unscrew the eight bottom cover screws (one of them is under the hand) using a screwdriver with a J1000 tip.
    • Unscrew the middle screw towards the top of the device using a screwdriver with a T5 tip.
  2. Asus Chromebook Flip C100 Lower Case Replacement: stap 2, afbeelding 1 van 1
    • Use the plastic opening tool to remove the four bottom rubber feet.
  3. Asus Chromebook Flip C100 Lower Case Replacement: stap 3, afbeelding 1 van 1
    • Unscrew the four screws under the feet using a screwdriver with a J100 tip.
  4. Asus Chromebook Flip C100 Lower Case Replacement: stap 4, afbeelding 1 van 1
    • Use the plastic opening tool to pry up the palm rest assembly.
  5. Asus Chromebook Flip C100 Lower Case Replacement: stap 5, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Disconnect the two cables from the motherboard with tweezers
Conclusie
11 andere personen hebben deze handleiding voltooid.
Jesse Ye
527 Reputatie
1 Handleiding geschreven
Één opmerking
great guide, though i found the nine screws on the outside required a t5 tip, while the 5 under the feet looked like they were either j100 or j1000, but a philips head worked.
Matthew Sylvester - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 5,115
