Ga door naar hoofdinhoud
Asus Chromebook C300MA-EDU Keyboard Replacement
Wat je nodig hebt
  1. Asus Chromebook C300MA-EDU Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 2 Asus Chromebook C300MA-EDU Keyboard Replacement, Keyboard: stap 1, afbeelding 2 van 2
    • Flip the Chromebook onto its back, where there are eleven screws.
    • There are two variations of screws on the back panel:
    • Six 8.7mm screws.
    • Five 6.4mm screws.
    • Using your screwdriver with the J00 Phillips Head tip, remove the screws by turning them counter clockwise.
  2. Asus Chromebook C300MA-EDU Keyboard Replacement: stap 2, afbeelding 1 van 2 Asus Chromebook C300MA-EDU Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Once the screws are removed, flip the Chromebook back over.
    • Gently remove the keyboard by starting to lift up on one corner with a plastic opening tool.
    • Follow around the brim of the keyboard until it pops off.
  3. Asus Chromebook C300MA-EDU Keyboard Replacement: stap 3, afbeelding 1 van 3 Asus Chromebook C300MA-EDU Keyboard Replacement: stap 3, afbeelding 2 van 3 Asus Chromebook C300MA-EDU Keyboard Replacement: stap 3, afbeelding 3 van 3
    • Once you remove the keyboard, it will be connected to the CPU with two tabbed connections.
    • Release the connections from the tabs gently by flipping the white flaps up until disconnected.
    • You can now pull the ribbons out from the board and remove the keyboard.
Conclusie
Christopher Hart
501 Reputatie
5 handleidingen geschreven
USF Tampa, Team S2-G3, Nance Fall 2017 Lid van USF Tampa, Team S2-G3, Nance Fall 2017
USFT-NANCE-F17S2G3
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 692
