Ga door naar hoofdinhoud
Asus Chromebook C300MA-DH02 Motherboard Replacement
Wat je nodig hebt
  1. Asus Chromebook C300MA-DH02 Motherboard Replacement, Keyboard Panel: stap 1, afbeelding 1 van 3 Asus Chromebook C300MA-DH02 Motherboard Replacement, Keyboard Panel: stap 1, afbeelding 2 van 3 Asus Chromebook C300MA-DH02 Motherboard Replacement, Keyboard Panel: stap 1, afbeelding 3 van 3
    • Flip the Chromebook over so that the underside is facing up.
    • Using the Phillips PH #000 screwdriver, remove the 11 "4mm" screws on the back of the device.
  2. Asus Chromebook C300MA-DH02 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Wedge the plastic opening tool between the bottom cover of the laptop and the keyboard panel.
    • Apply pressure and move the plastic opening tool around the border of the laptop until it pops out.
  3. Asus Chromebook C300MA-DH02 Motherboard Replacement: stap 3, afbeelding 1 van 2 Asus Chromebook C300MA-DH02 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Once the keyboard panel pops out, slowly move it upwards so that the keyboard connection is visible.
    • Remove the keyboard connection from the motherboard by pulling it outwards from the connector.
  4. Asus Chromebook C300MA-DH02 Motherboard Replacement, Motherboard: stap 4, afbeelding 1 van 2 Asus Chromebook C300MA-DH02 Motherboard Replacement, Motherboard: stap 4, afbeelding 2 van 2
    • Remove the 4 "4mm" screws on the silver motherboard cover with the Phillips #000 Screwdriver.
    • Remove the motherboard silver mount.
  5. Asus Chromebook C300MA-DH02 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Use a plastic opening tool to remove the connection from sound driver on the bottom left of the motherboard.
  6. Asus Chromebook C300MA-DH02 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Gently remove the blue connector to the right side of the motherboard.
  7. Asus Chromebook C300MA-DH02 Motherboard Replacement: stap 7, afbeelding 1 van 2 Asus Chromebook C300MA-DH02 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Use the Phillips #000 Screwdriver to remove the screw on right side of wireless card.
    • Remove the wireless card.
  8. Asus Chromebook C300MA-DH02 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Start by lifting tape up off of the connection. Remove the connection to display.
  9. Asus Chromebook C300MA-DH02 Motherboard Replacement: stap 9, afbeelding 1 van 3 Asus Chromebook C300MA-DH02 Motherboard Replacement: stap 9, afbeelding 2 van 3 Asus Chromebook C300MA-DH02 Motherboard Replacement: stap 9, afbeelding 3 van 3
    • Remove (3) three "4mm" screws that connect the hinge to the motherboard using the Phillips #000 Screwdriver.
    • Remove (5) five "4mm" screws around two sides of motherboard using the Phillips #000 Screwdriver.
  10. Asus Chromebook C300MA-DH02 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Gently remove motherboard from the Asus Chromebook.
Conclusie
Giang Le Nam Dang
149 Reputatie
1 Handleiding geschreven
USF Tampa, Team S6-G4, Remmell Fall 2017 Lid van USF Tampa, Team S6-G4, Remmell Fall 2017
USFT-REMMELL-F17S6G4
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 264
