Ga door naar hoofdinhoud
Asus Chromebook C300MA-DH02 Display Replacement
Wat je nodig hebt
  1. Asus Chromebook C300MA-DH02 Display Replacement, Keyboard Panel: stap 1, afbeelding 1 van 3 Asus Chromebook C300MA-DH02 Display Replacement, Keyboard Panel: stap 1, afbeelding 2 van 3 Asus Chromebook C300MA-DH02 Display Replacement, Keyboard Panel: stap 1, afbeelding 3 van 3
    • Flip the Chromebook over so that the underside is facing up.
    • Using the Phillips PH #000 screwdriver, remove the 11 "4mm" screws on the back of the device.
  2. Asus Chromebook C300MA-DH02 Display Replacement: stap 2, afbeelding 1 van 1
    • Wedge the plastic opening tool between the bottom cover of the laptop and the keyboard panel.
    • Apply pressure and move the plastic opening tool around the border of the laptop until it pops out.
  3. Asus Chromebook C300MA-DH02 Display Replacement: stap 3, afbeelding 1 van 2 Asus Chromebook C300MA-DH02 Display Replacement: stap 3, afbeelding 2 van 2
    • Once the keyboard panel pops out, slowly move it upwards so that the keyboard connection is visible.
    • Remove the keyboard connection from the motherboard by pulling it outwards from the connector.
  4. Asus Chromebook C300MA-DH02 Display Replacement, Display: stap 4, afbeelding 1 van 2 Asus Chromebook C300MA-DH02 Display Replacement, Display: stap 4, afbeelding 2 van 2
    • Remove the hinge protector by using the plastic opening tool to gently lift it up. It should come up easily.
  5. Asus Chromebook C300MA-DH02 Display Replacement: stap 5, afbeelding 1 van 2 Asus Chromebook C300MA-DH02 Display Replacement: stap 5, afbeelding 2 van 2
    • Using the plastic opening tool, separate the display cover bracket from the back of the display. Start from the top.
  6. Asus Chromebook C300MA-DH02 Display Replacement: stap 6, afbeelding 1 van 2 Asus Chromebook C300MA-DH02 Display Replacement: stap 6, afbeelding 2 van 2
    • Remove the (4) four "4mm" screws in each corner that hold the display using the Phillips #000 screwdriver.
  7. Asus Chromebook C300MA-DH02 Display Replacement: stap 7, afbeelding 1 van 1
    • Lower the display to allow access to connector in back.
  8. Asus Chromebook C300MA-DH02 Display Replacement: stap 8, afbeelding 1 van 2 Asus Chromebook C300MA-DH02 Display Replacement: stap 8, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Lift the tape covering the connector with the tweezers.
    • Gently remove the display connector from the motherboard.
Conclusie
Zachary Leonard
304 Reputatie
3 handleidingen geschreven
USF Tampa, Team S6-G4, Remmell Fall 2017 Lid van USF Tampa, Team S6-G4, Remmell Fall 2017
USFT-REMMELL-F17S6G4
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 228
