Inleiding
The battery is responsible for supplying power to the computer when the power adapter is not being used. You should get 10-11 hours of run-time with your battery. If the time is significantly shorter you should replace the battery even if it hasn't failed.
Wat je nodig hebt
Flip the Chromebook over so that the underside is facing up.
Using the Phillips PH #000 screwdriver, remove the 11 "4mm" screws on the back of the device.
Remove (6) six "4mm" screws that hold the battery using the Phillips #000 screwdriver.
Één andere persoon heeft deze handleiding voltooid.
