Ga door naar hoofdinhoud
Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement
Wat je nodig hebt
  1. Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Place device bottom-side up.
  2. Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement: stap 2, afbeelding 1 van 1
    • Remove the three 6.0 mm Philips screws from the center of the case with the #2 screwdriver bit.
    • Remove the eight 9.0 mm Philips screws along the perimeter of the case with the #2 screwdriver bit.
  3. Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement: stap 3, afbeelding 1 van 1
    • Using a plastic opening tool, separate the bottom case at the seam.
    • Prying open a laptop requires a lot of force but use caution so as to avoid breaking the fragile connectors.
  4. Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement: stap 4, afbeelding 1 van 2 Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement: stap 4, afbeelding 2 van 2
    • Lift the keyboard panel away from the components at its hinges, which are located at the back of the laptop.
  5. Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement, Battery: stap 5, afbeelding 1 van 1
    • Remove the six 6.0mm Philips screws, using the 64 bit driver from around the battery.
  6. Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement: stap 6, afbeelding 1 van 1
    • Unplug the wire using the plastic opening tool that connects the battery with the board.
  7. Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement: stap 7, afbeelding 1 van 1
    • Lift the battery out of the laptop
  8. Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement, Speakers: stap 8, afbeelding 1 van 1
    • Use plastic opening tool to pry off the wire connecting the left side speaker to the circuit board.
  9. Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement: stap 9, afbeelding 1 van 2 Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement: stap 9, afbeelding 2 van 2
    • Use plastic opening tool to pry off the left side speaker.
  10. Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement: stap 10, afbeelding 1 van 1
    • Gently remove the wire connecting the left and right speakers from it's channel. Be careful as to not tear or damage the wire.
  11. Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement: stap 11, afbeelding 1 van 1
    • Use plastic opening tool to pry off right side speaker.
  12. Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement: stap 12, afbeelding 1 van 1
    • Lift and remove both speakers and connecting wire.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
wyatt boyatt
541 Reputatie
5 handleidingen geschreven
USF Tampa, Team S4-G3, Eyestone Fall 2017 Lid van USF Tampa, Team S4-G3, Eyestone Fall 2017
USFT-EYESTONE-F17S4G3
3 Leden
12 handleidingen geschreven
2 opmerkingen
Bonjour m. Merci pour la présentation. Pourriez-vous m'indiquer l'endroit où je peux me procurer des haut-parleurs pour un hp Omen 15 ? Merci d'avance. Email : dhujardaim@hotmail.com / dhujardaim@gmail.com
dhujardaim@hotmail.com - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 143
