Ga door naar hoofdinhoud
Asus Chromebook C300MA-DB01 Mouse Pad Replacement
Wat je nodig hebt
  1. Asus Chromebook C300MA-DB01 Mouse Pad Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Place device bottom-side up.
  2. Asus Chromebook C300MA-DB01 Mouse Pad Replacement: stap 2, afbeelding 1 van 1
    • Remove the three 6.0 mm Philips screws from the center of the case with the #2 screwdriver bit.
    • Remove the eight 9.0 mm Philips screws along the perimeter of the case with the #2 screwdriver bit.
  3. Asus Chromebook C300MA-DB01 Mouse Pad Replacement: stap 3, afbeelding 1 van 1
    • Using a plastic opening tool, separate the bottom case at the seam.
    • Prying open a laptop requires a lot of force but use caution so as to avoid breaking the fragile connectors.
  4. Asus Chromebook C300MA-DB01 Mouse Pad Replacement: stap 4, afbeelding 1 van 2 Asus Chromebook C300MA-DB01 Mouse Pad Replacement: stap 4, afbeelding 2 van 2
    • Lift the keyboard panel away from the components at its hinges, which are located at the back of the laptop.
  5. Asus Chromebook C300MA-DB01 Mouse Pad Replacement, Mouse pad: stap 5, afbeelding 1 van 1
    • Use plastic opening tool to pry open clip holding keyboard wires to the circuit board.
    • Use plastic opening tool to pry open clip holding mouse pad wires to circuit board.
  6. Asus Chromebook C300MA-DB01 Mouse Pad Replacement: stap 6, afbeelding 1 van 2 Asus Chromebook C300MA-DB01 Mouse Pad Replacement: stap 6, afbeelding 2 van 2
    • Lift and remove keyboard from device. The keyboard and Mouse pad are one part that must be replaced simultaneously.
Conclusie
wyatt boyatt
541 Reputatie
5 handleidingen geschreven
USF Tampa, Team S4-G3, Eyestone Fall 2017 Lid van USF Tampa, Team S4-G3, Eyestone Fall 2017
USFT-EYESTONE-F17S4G3
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 142
