Ga door naar hoofdinhoud
Asus Chromebook C300MA-DB01 Back Cover Replacment
Wat je nodig hebt
  1. Asus Chromebook C300MA-DB01 Back Cover Replacment, Back Cover: stap 1, afbeelding 1 van 1
    • Place device bottom-side up.
  2. Asus Chromebook C300MA-DB01 Back Cover Replacment: stap 2, afbeelding 1 van 1
    • Remove the three 6.0 mm Philips screws from the center of the case with the #2 screwdriver bit.
    • Remove the eight 9.0 mm Philips screws along the perimeter of the case with the #2 screwdriver bit.
  3. Asus Chromebook C300MA-DB01 Back Cover Replacment: stap 3, afbeelding 1 van 1
    • Using a plastic opening tool, separate the bottom case at the seam.
    • Prying open a laptop requires a lot of force but use caution so as to avoid breaking the fragile connectors.
  4. Asus Chromebook C300MA-DB01 Back Cover Replacment: stap 4, afbeelding 1 van 2 Asus Chromebook C300MA-DB01 Back Cover Replacment: stap 4, afbeelding 2 van 2
    • Lift the keyboard panel away from the components at its hinges, which are located at the back of the laptop.
Conclusie
Gustavo Moncada Gomez
116 Reputatie
1 Handleiding geschreven
USF Tampa, Team S4-G3, Eyestone Fall 2017 Lid van USF Tampa, Team S4-G3, Eyestone Fall 2017
USFT-EYESTONE-F17S4G3
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 179
