Inleiding
This guide will show you how to open the casing on your Chromebook and remove your motherboard so that you can replace it.
Wat je nodig hebt
Remove the eight 9.0mm Phillips #00 screws.
Remove the three 6.0mm Phillips #00 screws.
Flip back the hinges on the connectors that secure the wide black cable and the narrow white cable using the tweezers.
Disconnect the wide black cable from the motherboard by pulling the blue cable tab away from the connector.
Disconnect the white ribbon cable from the motherboard by pulling the blue cable tab away from the connector.
Remove the two 6.0mm Phillips #00 screws that secure the metal heat shield to the motherboard.
Remove the metal heat shield.
