Inleiding
This guide will show you how to open the casing on your Chromebook and replace the LCD display.
Wat je nodig hebt
Wedge the tip of the plastic spudger between the outer display casing and the inner display panel liner.
Separate the outer display casing from the inner display panel by sliding the plastic spudger around the perimeter of the display.
Locate the gold cable connector that attaches the display to the bottom of the display housing.
Peel back the protective tape that covers the gold connector.
Disconnect the display from the display housing by gripping the sides of the gold display cable connector and pulling away from the bottom of the display.
