Ga door naar hoofdinhoud
Asus Chromebook C300MA-BBCLN12 Battery Replacement
Wat je nodig hebt
  1. Asus Chromebook C300MA-BBCLN12 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Asus Chromebook C300MA-BBCLN12 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the eight 9.0mm Phillips #00 screws.
    • Remove the three 6.0mm Phillips #00 screws.
  2. Asus Chromebook C300MA-BBCLN12 Battery Replacement: stap 2, afbeelding 1 van 3 Asus Chromebook C300MA-BBCLN12 Battery Replacement: stap 2, afbeelding 2 van 3 Asus Chromebook C300MA-BBCLN12 Battery Replacement: stap 2, afbeelding 3 van 3
    • Separate the palm rest assembly from the bottom housing using the plastic opening tool.
    • It is recommended that you start from a corner and run the plastic opening tool along the edge of the housing.
    • Lift the palm rest assembly slowly to prevent damaging the two cables that connect it to the motherboard.
  3. Asus Chromebook C300MA-BBCLN12 Battery Replacement: stap 3, afbeelding 1 van 3 Asus Chromebook C300MA-BBCLN12 Battery Replacement: stap 3, afbeelding 2 van 3 Asus Chromebook C300MA-BBCLN12 Battery Replacement: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Flip back the hinges on the connectors that secure the wide black cable and the narrow white cable using the tweezers.
    • Disconnect the wide black cable from the motherboard by pulling the blue cable tab away from the connector.
    • Disconnect the white ribbon cable from the motherboard by pulling the blue cable tab away from the connector.
  4. Asus Chromebook C300MA-BBCLN12 Battery Replacement: stap 4, afbeelding 1 van 1
    • Remove the six 6.0mm Phillips #00 screws that secure the battery to the bottom housing.
  5. Asus Chromebook C300MA-BBCLN12 Battery Replacement: stap 5, afbeelding 1 van 2 Asus Chromebook C300MA-BBCLN12 Battery Replacement: stap 5, afbeelding 2 van 2
    • Disconnect the bundled cable connector that attaches the battery to the motherboard using the small plastic spudger.
  6. Asus Chromebook C300MA-BBCLN12 Battery Replacement: stap 6, afbeelding 1 van 1
    • Remove the battery from the bottom housing.
Conclusie
Brooke Austin
419 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 406
