Ga door naar hoofdinhoud
Asus Chromebook C300MA DB01 Battery Replacement
Wat je nodig hebt
  1. Asus Chromebook C300MA DB01 Battery Replacement, Removing the Back Cover: stap 1, afbeelding 1 van 1
    • Remove the eight 9.0 mm Phillips screws along the perimeter of the case.
    • Remove the three 6.0 mm Phillips screws from the center of the case.
  2. Asus Chromebook C300MA DB01 Battery Replacement, Taking off the Keyboard: stap 2, afbeelding 1 van 2 Asus Chromebook C300MA DB01 Battery Replacement, Taking off the Keyboard: stap 2, afbeelding 2 van 2
    • Slide the Jimmy in between the keyboard and underside of the laptop to remove the keyboard.
    • Leave the keyboard face down on the screen.
    • Do not pull the keyboard away from the laptop. The keyboard will still be attached with wires.
  3. Asus Chromebook C300MA DB01 Battery Replacement, Detaching keyboard: stap 3, afbeelding 1 van 2 Asus Chromebook C300MA DB01 Battery Replacement, Detaching keyboard: stap 3, afbeelding 2 van 2
    • Use a nylon spudger to lift the latch on each wire jack and detach the keyboard wires.
    • After the tabs have been lifted, the wire can be gently pulled out by hand.
    • Set the keyboard aside.
  4. Asus Chromebook C300MA DB01 Battery Replacement, Removing the battery: stap 4, afbeelding 1 van 3 Asus Chromebook C300MA DB01 Battery Replacement, Removing the battery: stap 4, afbeelding 2 van 3 Asus Chromebook C300MA DB01 Battery Replacement, Removing the battery: stap 4, afbeelding 3 van 3
    • Remove the six 6.0mm Phillips screws on the battery.
    • Remove the wire jack from the battery. Use a nylon spudger to lift the latch.
    • Remove the battery from the device.
Conclusie
Earl Gill IV
193 Reputatie
2 handleidingen geschreven
IUPUI, Team S10-G10, Wilson Spring 2019 Lid van IUPUI, Team S10-G10, Wilson Spring 2019
IUPUI-WILSON-S19S10G10
3 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 189
