Inleiding
The touch pad (also called the track pad or mouse pad) is a component of the palm rest assembly. If only your touch pad, and not the entire palm rest assembly (i.e. keyboard) need replaced, then use this guide.
Wat je nodig hebt
Turn the device over so the bottom is facing up.
Remove the ten Phillips #1 8.0 mm screws.
Bijna klaar!
Conclusie
