Ga door naar hoofdinhoud
Asus A53U-ES21 Keyboard Replacement
Wat je nodig hebt
  1. Asus A53U-ES21 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 2 Asus A53U-ES21 Keyboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Make sure the laptop is off.
    • Flip the laptop upside down so that the battery is facing you.
  2. Asus A53U-ES21 Keyboard Replacement: stap 2, afbeelding 1 van 2 Asus A53U-ES21 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Move the two sliders towards the outer edge of the laptop.
    • Pull the battery out with your left hand while holding the right slider.
  3. Asus A53U-ES21 Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 3 Asus A53U-ES21 Keyboard Replacement, Keyboard: stap 3, afbeelding 2 van 3 Asus A53U-ES21 Keyboard Replacement, Keyboard: stap 3, afbeelding 3 van 3
    • Remove the RAM cover from the bottom of the keyboard.
    • Remove the 5mm screw keeping the panel in place using a Phillips #1 screwdriver.
    • Work the pry tool along the edge to finish removal.
    • Unscrew the two 7mm screws marked with an engraved "K" using a #1 Phillips screwdriver.
  4. Asus A53U-ES21 Keyboard Replacement: stap 4, afbeelding 1 van 3 Asus A53U-ES21 Keyboard Replacement: stap 4, afbeelding 2 van 3 Asus A53U-ES21 Keyboard Replacement: stap 4, afbeelding 3 van 3
    • Orient the computer so the keyboard is facing toward you with the screen at the top.
    • Find the three buttons to depress at top of the keyboard, set in the crack between the casing and the keyboard, highlighted here in red.
    • Use the pry tool to depress the buttons. The keyboard should pop out.
  5. Asus A53U-ES21 Keyboard Replacement: stap 5, afbeelding 1 van 3 Asus A53U-ES21 Keyboard Replacement: stap 5, afbeelding 2 van 3 Asus A53U-ES21 Keyboard Replacement: stap 5, afbeelding 3 van 3
    • Fold the keyboard out towards you. It should still be connected by a ribbon to the rest of the computer.
    • Gently use the opening tool to lift the black piece holding the ribbon down and remove the ribbon.
    • The black piece should cover the white line on the ribbon when it is replaced.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Mabel Trager
147 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team S1-G3, Simcock Fall 2018 Lid van UMass Dartmouth, Team S1-G3, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G3
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 524
