Ga door naar hoofdinhoud
Asus A53U-ES21 Keyboard Replacement
Wat je nodig hebt
    1. Asus A53U-ES21 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 2 Asus A53U-ES21 Keyboard Replacement, Battery: stap 1, afbeelding 2 van 2
      • Make sure the laptop is off.
      • Flip the laptop upside down so that the battery is facing you.
      Vraag FixBot
      Voeg opmerking toe
    2. Asus A53U-ES21 Keyboard Replacement: stap 2, afbeelding 1 van 2 Asus A53U-ES21 Keyboard Replacement: stap 2, afbeelding 2 van 2
      • Move the two sliders towards the outer edge of the laptop.
      • Pull the battery out with your left hand while holding the right slider.
      Vraag FixBot
      Voeg opmerking toe
    1. Asus A53U-ES21 Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 3 Asus A53U-ES21 Keyboard Replacement, Keyboard: stap 3, afbeelding 2 van 3 Asus A53U-ES21 Keyboard Replacement, Keyboard: stap 3, afbeelding 3 van 3
      • Remove the RAM cover from the bottom of the keyboard.
      • Remove the 5mm screw keeping the panel in place using a Phillips #1 screwdriver.
      • Work the pry tool along the edge to finish removal.
      • Unscrew the two 7mm screws marked with an engraved "K" using a #1 Phillips screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Asus A53U-ES21 Keyboard Replacement: stap 4, afbeelding 1 van 3 Asus A53U-ES21 Keyboard Replacement: stap 4, afbeelding 2 van 3 Asus A53U-ES21 Keyboard Replacement: stap 4, afbeelding 3 van 3
      • Orient the computer so the keyboard is facing toward you with the screen at the top.
      • Find the three buttons to depress at top of the keyboard, set in the crack between the casing and the keyboard, highlighted here in red.
      • Use the pry tool to depress the buttons. The keyboard should pop out.
      Vraag FixBot
      Voeg opmerking toe
    3. Asus A53U-ES21 Keyboard Replacement: stap 5, afbeelding 1 van 3 Asus A53U-ES21 Keyboard Replacement: stap 5, afbeelding 2 van 3 Asus A53U-ES21 Keyboard Replacement: stap 5, afbeelding 3 van 3
      • Fold the keyboard out towards you. It should still be connected by a ribbon to the rest of the computer.
      • Gently use the opening tool to lift the black piece holding the ribbon down and remove the ribbon.
      • The black piece should cover the white line on the ribbon when it is replaced.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Mabel Trager
180 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team S1-G3, Simcock Fall 2018 Lid van UMass Dartmouth, Team S1-G3, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G3
3 Leden
42 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 37
Altijd: 942
