Ga door naar hoofdinhoud
Inleiding
Remove the lower case of the ASUS A52F XE2 to gain access to internal parts.
Onderdelen
Geen onderdelen opgegeven.
  1. Place the laptop face down with the battery facing away from you. Locate the two buttons next to the battery.
    • Place the laptop face down with the battery facing away from you.
    • Locate the two buttons next to the battery.
    • Slide the right slider to the unlocked (red) position.
  2. Hold the left button to the left. Slide the battery with your other hand away from you and it should disconnect.
    • Hold the left button to the left.
    • Slide the battery with your other hand away from you and it should disconnect.
  3. Remove the five Phillips # 0 screws from the back panel. Using your finger or a plastic spudger start to carefully pry up the back planel. Using your finger or a plastic spudger start to carefully pry up the back planel.
    • Remove the five Phillips # 0 screws from the back panel.
    • Using your finger or a plastic spudger start to carefully pry up the back planel.
  4. Slide the back panel away and remove the panel. Slide the back panel away and remove the panel.
    • Slide the back panel away and remove the panel.
Conclusie
Michael Benson
113 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team S5-G1, Botvin Spring 2017 Lid van UMass Dartmouth, Team S5-G1, Botvin Spring 2017
UMASSD-BOTVIN-S17S5G1
4 Leden
7 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 287
