Ga door naar hoofdinhoud
Astro A50 2016 Base Station Motherboard Replacement
Wat je nodig hebt
  1. Astro A50 2016 Base Station Motherboard Replacement, Base Station Motherboard: stap 1, afbeelding 1 van 1
    • Remove the four rubber feet from the bottom of the base station using the plastic opening tool.
  2. Astro A50 2016 Base Station Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the ten 6 mm screws using a T8 screwdriver.
  3. Astro A50 2016 Base Station Motherboard Replacement: stap 3, afbeelding 1 van 2 Astro A50 2016 Base Station Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Remove the four 6 mm screws using a T6 screwdriver.
    • Remove each metal plate by lodging the plastic opening tool underneath it and using your hands to lift the plate away from the device.
  4. Astro A50 2016 Base Station Motherboard Replacement: stap 4, afbeelding 1 van 2 Astro A50 2016 Base Station Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Use your hand to gently pull the green side plates away from the center of the device.
  5. Astro A50 2016 Base Station Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the six 6mm screws using a T6 screwdriver.
  6. Astro A50 2016 Base Station Motherboard Replacement: stap 6, afbeelding 1 van 3 Astro A50 2016 Base Station Motherboard Replacement: stap 6, afbeelding 2 van 3 Astro A50 2016 Base Station Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Lift up the motherboard from the base station and pull it away from the device to remove it.
Conclusie
Vincent Seguin
379 Reputatie
3 handleidingen geschreven
Cal Poly, Team S15-G1, Livingston Fall 2017 Lid van Cal Poly, Team S15-G1, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G1
3 Leden
10 handleidingen geschreven
5 opmerkingen
my base station dont turen on, the front leds. any solution?
edgar jesus cortez cosio - Antwoord
my base station dont turns on the front leds, any solution?
having the same problem {with the front LEDs not turning on or it not being recognized by pc}what does the white button on the base station motherboard do?
Devin Danimals - Antwoord
Where can I purchase one of these motherboards?
he-g-man-aftermath - Antwoord
I need a new base board any ideas where I may purchase one
Paul Bishop - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 90
Altijd: 8,697
