Ga door naar hoofdinhoud
Astro A40 TR External Headband Replacement
Wat je nodig hebt
  1. Astro A40 TR External Headband Replacement, External Headband: stap 1, afbeelding 1 van 2 Astro A40 TR External Headband Replacement, External Headband: stap 1, afbeelding 2 van 2
    • Remove two hex screws on each side to free and remove the base plate. Do each step for both sides.
  2. Astro A40 TR External Headband Replacement: stap 2, afbeelding 1 van 2 Astro A40 TR External Headband Replacement: stap 2, afbeelding 2 van 2
    • Pull apart earpiece assembly and the connecting headband piece.
  3. Astro A40 TR External Headband Replacement: stap 3, afbeelding 1 van 2 Astro A40 TR External Headband Replacement: stap 3, afbeelding 2 van 2
    • Gently pull the padding layer off of both ends using your hands.
  4. Astro A40 TR External Headband Replacement: stap 4, afbeelding 1 van 3 Astro A40 TR External Headband Replacement: stap 4, afbeelding 2 van 3 Astro A40 TR External Headband Replacement: stap 4, afbeelding 3 van 3
    • Locate the black wiring and gently pull it out of the plastic headpiece component.
Conclusie
Mike
448 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 6-5, Martin Fall 2016 Lid van UMass Dartmouth, Team 6-5, Martin Fall 2016
UMASSD-MARTIN-F16S6G5
3 Leden
10 handleidingen geschreven
6 opmerkingen
Is there any place you can purchase a new external headband? The part that holds the foam piece in place broke on mine yesterday :(
zironyy - Antwoord
i dont have the screws i lost them when i dropped my headset
Sniping_Ninja10 - Antwoord
Did you buy screws? I need as well but I don’t know which one is good!
photo -
Where Can I buy screws for? I know the size is T8 but how long? which one is good for? Please help me
photo - Antwoord
where can i buy a new headband
Dewis Polonia - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 79
Altijd: 13,662
