Ga door naar hoofdinhoud
Astro A20 Cushion Replacement
Wat je nodig hebt
  1. Astro A20 Cushion  Replacement, Cushion: stap 1, afbeelding 1 van 1
    • Place one hand on the hard side of the headset ear portion and on the cushion.
    • Lift the small portion on the edge of the cushion.
  2. Astro A20 Cushion  Replacement: stap 2, afbeelding 1 van 1
    • Slide the metal spudger underneath the lift part of the ear cushion.
    • Pull the ear cushion while wedging the spudge around the edge of the ear cushion.
  3. Astro A20 Cushion  Replacement: stap 3, afbeelding 1 van 2 Astro A20 Cushion  Replacement: stap 3, afbeelding 2 van 2
    • Remove the ear cushion from the headset.
Conclusie
Jasmine Yarbrough
969 Reputatie
5 handleidingen geschreven
Één opmerking
The lighting is quite poor. I can't see what you're doing at all.
It's also missing a lot of information. Are they glued down? Are you able to get the ear cups off intact so they can be replaced after your wash them?
Vitrified Valkyrie - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 133
Altijd: 5,783
