Ga door naar hoofdinhoud
Assembling Parabolic Solar Cooker Tripod Base Stand
Wat je nodig hebt
  1. Assembling Parabolic Solar Cooker Tripod Base Stand, Assembling Parabolic Solar Cooker Tripod Base Stand: stap 1, afbeelding 1 van 2 Assembling Parabolic Solar Cooker Tripod Base Stand, Assembling Parabolic Solar Cooker Tripod Base Stand: stap 1, afbeelding 2 van 2
    • Insert a 14mm bolt through each tripod leg and through the center plate. Secure each bolt by hand threading a nut on the other side.
    • Be sure the flat side of each tripod leg is facing toward the ground.
  2. Assembling Parabolic Solar Cooker Tripod Base Stand: stap 2, afbeelding 1 van 1
    • Tighten each nut using two 14mm wrenches until each leg is stable and the tripod will stand on its own.
Conclusie
To disassemble your device, follow these instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
Ashlie Reott
340 Reputatie
3 handleidingen geschreven
Cal Poly, Team 4-30, Amido Fall 2013 Lid van Cal Poly, Team 4-30, Amido Fall 2013
CPSU-AMIDO-F13S4G30
4 Leden
6 handleidingen geschreven
1Gids Commentaar
Can I order the following part that was missing from the order that came in Aug 2025?
Please let me know, I can pay for these parts from you stock or spare parts.
36 x 10mm Nut/Bolt Pairs
6 Pipe Ring Brackets
12 x 14mm Nut/Bolt Pairs
2 Cooker Assembly Adjustment Star Knobs
Paul
my email is pn91006@yahoo.com
626-215-4038
Paul Ng
Paul Paul - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 47
Altijd: 897
