Ga door naar hoofdinhoud
Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar
Wat je nodig hebt
  1. Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar, Assembling Parabolic Solar Cooker Tripod Base Stand: stap 1, afbeelding 1 van 2 Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar, Assembling Parabolic Solar Cooker Tripod Base Stand: stap 1, afbeelding 2 van 2
    • Insert a 14mm bolt through each tripod leg and through the center plate. Secure each bolt by hand threading a nut on the other side.
    • Be sure the flat side of each tripod leg is facing toward the ground.
  2. Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar: stap 2, afbeelding 1 van 1
    • Tighten each nut using two 14mm wrenches until each leg is stable and the tripod will stand on its own.
  3. Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar, Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar: stap 3, afbeelding 1 van 2 Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar, Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar: stap 3, afbeelding 2 van 2
    • Center the bottom of the expansion pipe between the tabs of the t-bar bracket. Insert a 14mm bolt through the bracket and expansion pipe and hand thread a nut. Use 14mm wrenches to secure the assembly.
    • It does not matter which direction the 14mm bolt is inserted from.
Conclusie
To disassemble your device, follow these instructions in reverse order.
Ashlie Reott
340 Reputatie
3 handleidingen geschreven
Cal Poly, Team 4-30, Amido Fall 2013 Lid van Cal Poly, Team 4-30, Amido Fall 2013
CPSU-AMIDO-F13S4G30
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 12
Altijd: 534
