Inleiding
In diesem Guide werde ich dir Zeigen wie du ganz einfach und ohne Komplikationen die 12 AX7A Röhre aus deinem Tube Art MP austauschen kannst
Wat je nodig hebt
Herzlichen Glückwunsch du hast es geschafft :)
3 andere personen hebben deze handleiding voltooid.
3 opmerkingen
A tube replacement for this device is not necessarily meant for broken tubes. Most people do it for altering the sound. There is still a modification manual on the web for changing most of the parts like resistors, capacitors and ICs for higher quality.
I didn’t find it necessary to remove the motherboard to replace the tube. The card where the tube socket is located is connected to the main board with two cables. That board may be lifted clear of the chassis just by extending those cables.
