Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove four 5 mm Phillips #00 screws from each corner of the tablet.
Place the iFixit opening tool in the notches between the cases and pull the covers apart.
Repeat step two until 3/4 of the rear cover is unlatched.
Proceed to remove the rear cover by gently pulling it apart by hand.
Locate the two lower bumpers on the back cover. These are the rubber feet.
Flip the cover over to reveal the inside.
Locate the two rubber tabs, there are two for each rubber foot. They are located on the inside of the cover.
Push the two tabs on each foot down using the pointed end of a spudger.
Flip the cover back over so you see the outside. Remove the rubber feet if they have not already fallen out.
