Ga door naar hoofdinhoud
Inleiding
The rubber feet/bumpers on any device can get lost or damaged. This guide will show you how to replace those bumpers on an Arnova 7K G3. First, the disassembly guide to remove the rear cover must be completed and it is included in this guide.
Onderdelen
Geen onderdelen opgegeven.
  1. Arnova 7K G3 Rubber Feet Replacement, Rear Cover: stap 1, afbeelding 1 van 3 Arnova 7K G3 Rubber Feet Replacement, Rear Cover: stap 1, afbeelding 2 van 3 Arnova 7K G3 Rubber Feet Replacement, Rear Cover: stap 1, afbeelding 3 van 3
    • Remove four 5 mm Phillips #00 screws from each corner of the tablet.
  2. Arnova 7K G3 Rubber Feet Replacement: stap 2, afbeelding 1 van 2 Arnova 7K G3 Rubber Feet Replacement: stap 2, afbeelding 2 van 2
    • Place the iFixit opening tool in the notches between the cases and pull the covers apart.
  3. Arnova 7K G3 Rubber Feet Replacement: stap 3, afbeelding 1 van 1
    • Repeat step two until 3/4 of the rear cover is unlatched.
    • Proceed to remove the rear cover by gently pulling it apart by hand.
  4. Arnova 7K G3 Rubber Feet Replacement, Rubber Feet: stap 4, afbeelding 1 van 2 Arnova 7K G3 Rubber Feet Replacement, Rubber Feet: stap 4, afbeelding 2 van 2
    • Locate the two lower bumpers on the back cover. These are the rubber feet.
    • Flip the cover over to reveal the inside.
    • Locate the two rubber tabs, there are two for each rubber foot. They are located on the inside of the cover.
  5. Arnova 7K G3 Rubber Feet Replacement: stap 5, afbeelding 1 van 1
    • Push the two tabs on each foot down using the pointed end of a spudger.
    • It may take some force to push in the tabs. Prying with the pointed end of the spudger and wiggling the tab free may be necessary.
  6. Arnova 7K G3 Rubber Feet Replacement: stap 6, afbeelding 1 van 1
    • Flip the cover back over so you see the outside. Remove the rubber feet if they have not already fallen out.
Conclusie
To reassemble your device, follow these instructions in reverse order with the new rubber feet.
Tyler Sigafoose
210 Reputatie
2 handleidingen geschreven
Michigan Tech, Team 1-2, Lauer Spring 2015 Lid van Michigan Tech, Team 1-2, Lauer Spring 2015
MTU-LAUER-S15S1G2
2 Leden
10 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 135
