Ga door naar hoofdinhoud
Archos Jukebox Recorder 20 Hard Drive Replacement
Wat je nodig hebt
  1. Archos Jukebox Recorder 20 Hard Drive  Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the plastic cover over the batteries on both sides of the device.
  2. Archos Jukebox Recorder 20 Hard Drive  Replacement: stap 2, afbeelding 1 van 1
    • Remove the batteries (may require a plastic opening tool or spudger to pop the batteries out).
  3. Archos Jukebox Recorder 20 Hard Drive  Replacement, Hard Drive: stap 3, afbeelding 1 van 2 Archos Jukebox Recorder 20 Hard Drive  Replacement, Hard Drive: stap 3, afbeelding 2 van 2
    • Use the T10 Torx Screwdriver to remove the 2 torx screws on each side of the device.
    • Two on each side for a total of four.
  4. Archos Jukebox Recorder 20 Hard Drive  Replacement: stap 4, afbeelding 1 van 2 Archos Jukebox Recorder 20 Hard Drive  Replacement: stap 4, afbeelding 2 van 2
    • Remove the 2 screws on the top and the 2 screws on the bottom of the device using a Phillips #0 screwdriver.
  5. Archos Jukebox Recorder 20 Hard Drive  Replacement: stap 5, afbeelding 1 van 1
    • Remove the outer metal casing of the device by popping it off with a plastic opening tool.
  6. Archos Jukebox Recorder 20 Hard Drive  Replacement: stap 6, afbeelding 1 van 1
    • Remove the rubber bumpers on all four corners of the device.
  7. Archos Jukebox Recorder 20 Hard Drive  Replacement: stap 7, afbeelding 1 van 2 Archos Jukebox Recorder 20 Hard Drive  Replacement: stap 7, afbeelding 2 van 2
    • Lift the hard drive out of its casing with the help of a plastic opening tool and slide it out. This will disconnect the pins connecting the drive to the rest of the device.
Conclusie
Aidan Patterson
354 Reputatie
2 handleidingen geschreven
IUPUI, Team S1-G4, Freund Spring 2018 Lid van IUPUI, Team S1-G4, Freund Spring 2018
IUPUI-FREUND-S18S1G4
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 25
Altijd: 1,318
