Ga door naar hoofdinhoud
Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement
Wat je nodig hebt
  1. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement, 20-inch Sediment Pre-Filter: stap 1, afbeelding 1 van 2 Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement, 20-inch Sediment Pre-Filter: stap 1, afbeelding 2 van 2
    • Turn off the water supply by turning the water valve(s) to be horizontal, or perpendicular to the water pipe.
    • You may have one or two valves depending on the installation of your system.
  2. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: stap 2, afbeelding 1 van 1
    • Press the black pressure release button on top of the filter housing.
    • Hold the button down for 5 seconds.
  3. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: stap 3, afbeelding 1 van 3 Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: stap 3, afbeelding 2 van 3 Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: stap 3, afbeelding 3 van 3
    • Unscrew the filter housing canister clockwise with a water filter housing wrench.
  4. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: stap 4, afbeelding 1 van 1
    • Remove the dirty pre-filter and dispose of it.
  5. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: stap 5, afbeelding 1 van 3 Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: stap 5, afbeelding 2 van 3 Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: stap 5, afbeelding 3 van 3
    • Wash the filter housing canister with dish soap and water.
    • You may need a long-handled cleaning brush to scrub off dirt and debris.
    • Rinse and dry the filter housing canister.
  6. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: stap 6, afbeelding 1 van 1
    • Remove the O-ring from the housing canister.
  7. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: stap 7, afbeelding 1 van 1
    • Clean off old grease on the O-ring with a towel.
  8. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: stap 8, afbeelding 1 van 2 Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: stap 8, afbeelding 2 van 2
    • Replace the O-ring.
    • Apply Vaseline or lube around the seal.
  9. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: stap 9, afbeelding 1 van 2 Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: stap 9, afbeelding 2 van 2
    • Place the new pre-filter in the center of the filter housing canister.
  10. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: stap 10, afbeelding 1 van 2 Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: stap 10, afbeelding 2 van 2
    • Screw the filter housing canister counter-clockwise with your hands.
  11. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: stap 11, afbeelding 1 van 1
    • Tighten the filter housing canister with the filter wrench.
  12. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: stap 12, afbeelding 1 van 2 Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: stap 12, afbeelding 2 van 2
    • Turn on the water supply by turning the water valve(s) to be vertical, or parallel to the water pipe.
  13. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: stap 13, afbeelding 1 van 1
    • Run water in a sink or tub for 1-2 minutes to flush out the system and remove any air in the pipes.
Conclusie
Repeat steps every 2-3 months for best results.
Één andere persoon heeft deze handleiding voltooid.
Kathryn Hall
247 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 24
Altijd: 246
