Ga door naar hoofdinhoud
Aquarium CO2 System Replacement
Wat je nodig hebt
  1. Aquarium CO2 System Replacement, CO2 System: stap 1, afbeelding 1 van 1
    • Using the funnel, pour 1 teaspoon of baking soda, 7 tablespoons of sugar, 2 cups of lukewarm water, and 2 teaspoons of yeast into the 2L empty bottle.
  2. Aquarium CO2 System Replacement: stap 2, afbeelding 1 van 1
    • Close the bottle.
    • Shake the bottle rapidly for 15 seconds (or until the liquid has turned milky-white).
  3. Aquarium CO2 System Replacement: stap 3, afbeelding 1 van 3 Aquarium CO2 System Replacement: stap 3, afbeelding 2 van 3 Aquarium CO2 System Replacement: stap 3, afbeelding 3 van 3
    • Poke, drill, or cut a small hole in a 2L bottle cap and insert an airline tubing adaptor.
    • Use some kind of glue or sealant to seal the top of the bottle cap, ensuring an airtight fit.
    • Connect one end of the airline tubing to the airline tubing adapter, and the other end of the airline tubing to the CO2 diffuser.
  4. Aquarium CO2 System Replacement: stap 4, afbeelding 1 van 1
    • Seal the bottle with the airline tubing adapter by screwing it onto the top of bottle's open lid.
  5. Aquarium CO2 System Replacement: stap 5, afbeelding 1 van 1
    • Place the CO2 diffuser on the inside of the aquarium tank at below half-depth of the water-level.
    • Most CO2 diffusers are able to be stuck to the inside glass of the tank to achieve stronger stability.
    • Make sure the bottle is not placed too far away from the aquarium tank as to avoid any accidents or tears with the airline tubing.
Eindstreep
Aryan Haghighi
121 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 9
Altijd: 137
