Ga door naar hoofdinhoud
Apple iPod Hi-Fi Grille Replacement
Wat je nodig hebt
  1. Apple iPod Hi-Fi Grille Replacement, Grille: stap 1, afbeelding 1 van 1
    • Warm up the glue by using the hair dryer on the grille for 5-10 minutes.
    • You can skip this step if you don't have access to a hair dryer. However, if you skip this step, the next step will take longer and will be harder.
  2. Apple iPod Hi-Fi Grille Replacement: stap 2, afbeelding 1 van 1
    • Take one spudger and fit it under the grille.
    • Use your first spudger to pry up and make room to insert a second one.
    • Sever the glue connections between the grille and the device by moving one spudger around, cutting through the glue.
    • Use the other spudger to raise the grille, allowing you to see where you're working.
    • Since you're cutting the glue, the grille may not stick as well when reassembled.
  3. Apple iPod Hi-Fi Grille Replacement: stap 3, afbeelding 1 van 1
    • Pull the grille off the Apple iPod Hi-Fi with your hands.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Timothy Scheuermann
710 Reputatie
3 handleidingen geschreven
Cal Poly, Team S16-G1, Livingston Spring 2018 Lid van Cal Poly, Team S16-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G1
5 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 28
Altijd: 1,425
