Ga door naar hoofdinhoud
Apple Wireless Keyboard Logic Board Replacement
Wat je nodig hebt
  1. Apple Wireless Keyboard Logic Board Replacement, Logic Board: stap 1, afbeelding 1 van 2 Apple Wireless Keyboard Logic Board Replacement, Logic Board: stap 1, afbeelding 2 van 2
    • Insert a metal spudger to open the plastic part under the Keyboard
  2. Apple Wireless Keyboard Logic Board Replacement: stap 2, afbeelding 1 van 1
    • Remove the screw
  3. Apple Wireless Keyboard Logic Board Replacement: stap 3, afbeelding 1 van 3 Apple Wireless Keyboard Logic Board Replacement: stap 3, afbeelding 2 van 3 Apple Wireless Keyboard Logic Board Replacement: stap 3, afbeelding 3 van 3
    • Pull the lock up and disconnect the connection cable
  4. Apple Wireless Keyboard Logic Board Replacement: stap 4, afbeelding 1 van 1
    • Keeping the connection cable, push out the logic board's placement
  5. Apple Wireless Keyboard Logic Board Replacement: stap 5, afbeelding 1 van 1
    • Unlock the latch of the logic board
  6. Apple Wireless Keyboard Logic Board Replacement: stap 6, afbeelding 1 van 1
    • Remove the logic board from the placement
Conclusie
20 andere personen hebben deze handleiding voltooid.
Nicola
638 Reputatie
1 Handleiding geschreven
9 opmerkingen
Hi, anyone know where its possible to buy this logic board? My bluetooth chip is apparently broken
steve - Antwoord
Which model of keyboard is this, because my A1255 doesn't disassemble like this - the battery terminal is solidly restrained inside the tube by means of a metal expansion ring. Doesn't seem user repairable :(
gordon jackson - Antwoord
My power button was stuck. The shell was dented. This was an easier way to access and remove the button so I was able to file the inside of the tube smooth so the button would move freely.
Tony - Antwoord
I have disassembled my keyboard as shown above, but now I need a replacement Wireless Keyboard Logic Board. I have not been able to find one. Any suggestions?
Martin Rubio - Antwoord
Very nice! in my case the flat cable was not properly connecting. I only found out when i opened the cap to the logic board and saw the cable sitting slanted in its connector. Put it back straight and now it works again. Cheers!!
mollymol - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 95
Altijd: 48,128
