Inleiding
The base plate serves as the under casing for the device. It provide structural security and protection for the internal components. If the base plate is damaged it may put the internal hardware at risk and should be replaced. The rubber covering is held in place by an adhesive and make take some time remove.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Turn the device upside down to reveal the rubber section of the back plate. Using a metal spudger, carefully wedge the blunt tip into the space between the aluminum back plate and the rubber, separating the two pieces.
9 andere personen hebben deze handleiding voltooid.
