Inleiding
This guide will show you how to remove the power supply/heatsink of the Apple TV so it may be replaced.
Wat je nodig hebt
Remove the 4mm T7 Torx screw.
Remove the 5mm T7 Torx screw and its accompanying washer.
Remove the four (4) 4mm T7 Torx screws anchoring the power supply to the case.
Remove the two (2) 4mm T6 Torx screws holding the power supply plug.
8 andere personen hebben deze handleiding voltooid.
5 opmerkingen
Where could one find such a power supply for the 4th generation Apple TV. Sadly this one went out without even a years worth of light use.
Lewis,
If its under a year just have apple replace it. I just replaced the powersupply with one I aquired on ebay. It didn’t power on when I was done with the fix. I didn’t go all inspector gadget on it, but with the plethora of heatsinks on this thing I bet some circuitry fried due to a heat issue.
This instructions were perfect. Found power supply, replaced in about 15mins. Apple TV powers up again. Saved me from buying another.
THANK YOU
New Power Supply Board PA-1110-7A1 for Apple TV 4th Generation A1625by WFLNHBLearn more: https://www.amazon.com/dp/B07R4LBZ16/ref...
