Inleiding
This guide will show you how to remove the logic board of the Apple TV so it may be replaced.
Wat je nodig hebt
Unplug all cables from the Apple TV before disassembly and flip the device over.
Using the widest plastic opening tool, force its sharp end into the seam between the Apple TV's bottom plate and its outer casing. Starting on the side with the ports, insert the tool so its tip is angled upward when leverage is applied.
Pry the bottom plate away from the case, starting with the edge closest to the bottom of the apple. Work your way around the plate until all clips are disconnected.
With the plastic clips free, lift the bottom plate.
Remove the five (5) 7mm T7 Torx screws.
Pull upward on the edges of the shield.
Remove the 4mm T7 Torx screw.
Remove the 5mm T7 Torx screw and its accompanying washer.
4 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Can a replacement logic board be bought online ? What is the part number ?
Thank You
Where can I find a replacement logic board?! I can’t seem to find a website with one anywhere!
