Ga door naar hoofdinhoud
Apple TV 4K Remote Logic Board Replacement
Wat je nodig hebt
  1. Apple TV 4K Remote Logic Board Replacement, Remote Logic Board: stap 1, afbeelding 1 van 1
    • Heat iOpener according to manufacturer's instructions.
    • Place over the face of the remote to soften the adhesive under the glass.
  2. Apple TV 4K Remote Logic Board Replacement: stap 2, afbeelding 1 van 2 Apple TV 4K Remote Logic Board Replacement: stap 2, afbeelding 2 van 2
    • Using a spudger, gently lift the face of the remote. Starting from the bottom and working your way to the top.
  3. Apple TV 4K Remote Logic Board Replacement: stap 3, afbeelding 1 van 1
    • Push front face forward to disengage plastic clips at the top of the remote.
  4. Apple TV 4K Remote Logic Board Replacement: stap 4, afbeelding 1 van 2 Apple TV 4K Remote Logic Board Replacement: stap 4, afbeelding 2 van 2
    • Unlatch the connector that binds the touch screen and logic board.
    • Afterwards, use tweezers to detach the connector that binds the touch screen to the logic board.
  5. Apple TV 4K Remote Logic Board Replacement: stap 5, afbeelding 1 van 1
    • Lift the face from the body of the remote.
  6. Apple TV 4K Remote Logic Board Replacement: stap 6, afbeelding 1 van 2 Apple TV 4K Remote Logic Board Replacement: stap 6, afbeelding 2 van 2
    • Lift the latch holding back the connector to the battery.
    • Use tweezers to disconnect the battery connector.
  7. Apple TV 4K Remote Logic Board Replacement: stap 7, afbeelding 1 van 1
    • Remove the following screws using a T3 Torx screwdriver:
    • Eight 2mm screws
  8. Apple TV 4K Remote Logic Board Replacement: stap 8, afbeelding 1 van 1
    • Using a plastic spudger, gently remove the logic board from the case of the remote.
Conclusie
Keenan Barber
1.159 Reputatie
3 handleidingen geschreven
UW Stout, Team S6-G3, Ogden Fall 2018 Lid van UW Stout, Team S6-G3, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G3
4 Leden
15 handleidingen geschreven
Één opmerking
Have you ever successfully reconnected the ribbon cable after disassembly? It seems nearly impossible to do by hand…
B R - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 42
Afgelopen 30 dagen: 103
Altijd: 4,320
