Inleiding
This guide will show you how to dissemble and replace the power connector on your Apple TV 4K.
Wat je nodig hebt
Use a spudger to pry the bottom panel off from the body. It is held on with clips on the inside, so you will need to make sure those are undone while opening.
Use a T7 Torx to remove the screws:
Five 5mm screws
Carefully flip the device upside down to remove the logic board/power supply mount.
Bijna klaar!
Conclusie
