Inleiding
This guide will show you how to properly get into your Apple TV 4K device and get access to the logic board for replacement.
Wat je nodig hebt
Use a spudger to pry the bottom panel off from the body. It is held on with clips on the inside, so you will need to make sure those are undone while opening.
8 andere personen hebben deze handleiding voltooid.
8 opmerkingen
Any idea on where I can purchase. new logic board?
Where do you buy the board…….
You’ll only be able to buy replacement boards on eBay or similar. I have successfully repaired a number of Apple TV 4K that had no power issues by fixing various shorted components.
Currently not possible to buy the board. But you can buy the power supply here. We have seen many problems with random restarting of apple TV 4K. Solution is to repair the board chip.
There are three clips on each side - short after the beginning of the rounding on each side, and one middle.
The bottom panel is approx 5mm in height and a little bit flexible.
hackgreti - Antwoord
