Ga door naar hoofdinhoud
Apple TV 4K Logic Board Replacement
Wat je nodig hebt
  1. Apple TV 4K Logic Board Replacement, Logic Board: stap 1, afbeelding 1 van 1
    • Use a spudger to pry the bottom panel off from the body. It is held on with clips on the inside, so you will need to make sure those are undone while opening.
    • The panel is held onto the device tightly, so you may need to be a bit forceful to remove it.
  2. Apple TV 4K Logic Board Replacement: stap 2, afbeelding 1 van 2 Apple TV 4K Logic Board Replacement: stap 2, afbeelding 2 van 2
    • Remove the following screws using a T6 Torx screwdriver holding the heat sink assembly in.
    • Four 10 mm screws
    • Lift and remove the heat sink assembly from the device.
  3. Apple TV 4K Logic Board Replacement: stap 3, afbeelding 1 van 2 Apple TV 4K Logic Board Replacement: stap 3, afbeelding 2 van 2
    • Use plastic spudger to pull up on all three antenna connectors to remove them.
    • Remove rubber piece from front side of device.
  4. Apple TV 4K Logic Board Replacement: stap 4, afbeelding 1 van 1
    • Unscrew the following screws holding the logic board in place using the T7 Torx:
    • Two black 3 mm screws
    • Two silver 4 mm screws
  5. Apple TV 4K Logic Board Replacement: stap 5, afbeelding 1 van 3 Apple TV 4K Logic Board Replacement: stap 5, afbeelding 2 van 3 Apple TV 4K Logic Board Replacement: stap 5, afbeelding 3 van 3
    • Use a spudger to pry up logic board. Try lifting it up from the front side.
    • Remove logic board and set aside.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Keenan Barber
1.159 Reputatie
3 handleidingen geschreven
UW Stout, Team S6-G3, Ogden Fall 2018 Lid van UW Stout, Team S6-G3, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G3
4 Leden
15 handleidingen geschreven
8 opmerkingen
Where does one get a new logic board??
MP94025 - Antwoord
Any idea on where I can purchase. new logic board?
tylerchumchal - Antwoord
Where do you buy the board…….
Andy Grichtmeier - Antwoord
Good job on showing how to remove and replace logic board. Now as the other three commentators have asked
, where can you buy another one or is an exercise in futility
Kanehoe - Antwoord
Hm. Has anyone’s Apple TV 4k logic board failed?
oTWR - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 114
Altijd: 8,036
