Ga door naar hoofdinhoud
Apple TV 2nd Generation Power Supply Replacement
Wat je nodig hebt
  1. Apple TV 2nd Generation Power Supply Replacement, Power Supply: stap 1, afbeelding 1 van 2 Apple TV 2nd Generation Power Supply Replacement, Power Supply: stap 1, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Metal Spudger
    $2.99
    Koop
    • As the Apple TV doesn’t have any visible screws or point of entry, the first step is to use a couple of metal spudgers to carefully loosen and remove the rubber base from the upper case.
    • Upon opening the Apple TV, the most noticeable and largest parts will be the heat sink and power supply.
  2. Apple TV 2nd Generation Power Supply Replacement: stap 2, afbeelding 1 van 3 Apple TV 2nd Generation Power Supply Replacement: stap 2, afbeelding 2 van 3 Apple TV 2nd Generation Power Supply Replacement: stap 2, afbeelding 3 van 3
    Phillips #1 Screwdriver
    $5.49
    Koop
    • Using a #1 Phillips screwdriver, remove the screws holding the heat sink in place.
    • Remember, there are also screws hidden underneath the thermal pad.
    • Next, use a metal spudger to gently pry the logic board up and out of the device. This will allow easier access to the power supply.
  3. Apple TV 2nd Generation Power Supply Replacement: stap 3, afbeelding 1 van 2 Apple TV 2nd Generation Power Supply Replacement: stap 3, afbeelding 2 van 2
    Koop
    • The power supply is attached at three different points: the logic board/power supply connector, two screws and a heavy piece of tape, located underneath the power supply.
    • Locate the connector attaching the power supply to the logic board. Using a pair of tweezers, gently remove the connector from the power supply.
    • Using a #1 Phillips screwdriver, remove the two screws located toward the front of the device.
  4. Apple TV 2nd Generation Power Supply Replacement: stap 4, afbeelding 1 van 2 Apple TV 2nd Generation Power Supply Replacement: stap 4, afbeelding 2 van 2
    • Using a nylon spudger around the edge, gently work the power supply up and out of the case.
    • Place the replacement power supply in the now empty spot.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Deanna Rice
261 Reputatie
2 handleidingen geschreven
2 opmerkingen
There is actually no need to take out the heat sink, just open the bottom, unscrew the power connector, unplug the 8-pin connector from power supply and the power supply is free.
skvarlamatus - Antwoord
My power supply of apple tv 2nd gen is damaged, it is not available?
Ceporce - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 23
Altijd: 1,772
