Ga door naar hoofdinhoud
Apple TV 2nd Generation Logic Board Replacement
Wat je nodig hebt
  1. Apple TV 2nd Generation Logic Board Replacement, Logic Board: stap 1, afbeelding 1 van 2 Apple TV 2nd Generation Logic Board Replacement, Logic Board: stap 1, afbeelding 2 van 2
    • Use a spudger to pry the bottom cover off the Apple TV.
    • It may be necessary to use two spudgers (one to hold it open while you pry with the other one)
  2. Apple TV 2nd Generation Logic Board Replacement: stap 2, afbeelding 1 van 1
    • Carefully remove the bottom cover from the unit
  3. Apple TV 2nd Generation Logic Board Replacement: stap 3, afbeelding 1 van 2 Apple TV 2nd Generation Logic Board Replacement: stap 3, afbeelding 2 van 2
    • Remove the pink thermal pad. (I already removed mine)
    • Remove the five philips #1 screws securing the heatsink and logic board to the upper casing.
  4. Apple TV 2nd Generation Logic Board Replacement: stap 4, afbeelding 1 van 2 Apple TV 2nd Generation Logic Board Replacement: stap 4, afbeelding 2 van 2
    • Using a screwdriver (flathead) or a spudger, pull the power cable out of the logic board
    • Now with a spudger or flathead screw driver, CAREFULLY remove the LED connector. Do this very carefully as this connector is extreme fragile, and easily damaged.
  5. Apple TV 2nd Generation Logic Board Replacement: stap 5, afbeelding 1 van 3 Apple TV 2nd Generation Logic Board Replacement: stap 5, afbeelding 2 van 3 Apple TV 2nd Generation Logic Board Replacement: stap 5, afbeelding 3 van 3
    • Use a flathead screwdriver or spudger to tilit the logic board to an angle so you can grab it with your hands
    • Holding the logic board by it edges, lift it up slightly.
    • And remove
    • Thats all. The logic board has been removed. Just follow the steps (Step 1-5 in reverse to install the board)
  6. Apple TV 2nd Generation Logic Board Replacement: stap 6, afbeelding 1 van 3 Apple TV 2nd Generation Logic Board Replacement: stap 6, afbeelding 2 van 3 Apple TV 2nd Generation Logic Board Replacement: stap 6, afbeelding 3 van 3
    • The chip with the grease on is the Apple A4 chip. The thermal pad took the silkscreen off, so its hard to read.
    • The The black ball surrounded by meta is the IR Remote sensor.
    • In the third picture, the power connector and LED status connector are shown.
  7. Apple TV 2nd Generation Logic Board Replacement: stap 7, afbeelding 1 van 2 Apple TV 2nd Generation Logic Board Replacement: stap 7, afbeelding 2 van 2
    • HDMI Port
    • Micro USB Port (used for diagnostics, and service)
    • Digital TOS Link out (Optical Out)
    • Gigabit Ethernet
    • The second picture shows the thermal pads (pinkish white edge stuff) this keeps the components of the logic board cool and happy.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Nicholas Ouimet
3.548 Reputatie
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 12,935
