Ga door naar hoofdinhoud
Apple TV 2nd Generation Heat Sink Replacement
Wat je nodig hebt
  1. Apple TV 2nd Generation Heat Sink Replacement, Heat Sink: stap 1, afbeelding 1 van 2 Apple TV 2nd Generation Heat Sink Replacement, Heat Sink: stap 1, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Metal Spudger
    $2.99
    Koop
    • The Apple TV has no visible screws or visible areas of entry. Therefore, we must first begin by using a metal spudger or two and inserting them between the rubber-coated base and the upper case
    • With some careful maneuvering, the Apple TV base should pop off.
    • A large pink square will be visible once the base is removed. This is the thermal pad.
    • The heat sink is the large black piece holding the thermal pad in place. The heat sink is metal and it’s purpose is to draw heat away from the chips inside the device.
  2. Apple TV 2nd Generation Heat Sink Replacement: stap 2, afbeelding 1 van 3 Apple TV 2nd Generation Heat Sink Replacement: stap 2, afbeelding 2 van 3 Apple TV 2nd Generation Heat Sink Replacement: stap 2, afbeelding 3 van 3
    Phillips #1 Screwdriver
    $5.49
    Koop
    • The thermal pad should come off in one piece. After it is off, use a Phillips screwdriver to remove the five screws holding the heat sink in place.
    • Once the screws are removed, it will be easy to separate the heat sink from the PCB. You will also notice a second thermal pad located under the heat sink. You may remove this pad as well.
    • Once the pads are removed, they may either be reattached to a new heat sink or new thermal pads may be placed on the new heatsink.
Conclusie
Areej Bashawiri
201 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 687
