Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Position the Powerbook towards you with the monitor closed.
Press the battery removal latch located on the right side of the front panel.
Gently slide the battery out.
Turn the laptop over and remove the three T8 torx screws from the bottom panel.
Turn the laptop back over and open the monitor.
With the monitor facing towards you, gently pull up on the keyboard panel from the bottom.
To begin, carefully grip the bottom portion of the computer as pictured.
Next, lift up on the front portion of the laptop.
Carefully disconnect it by grasping the cable, pulling straight up and out of its connector.
While holding the mouse button in place, unscrew the two screws (Torx #8 ).
Then slide the button out, maintaining hold of the cable as pictured.
Unscrew the last torx #8 screw holding the trackpad assembly in place.
Disconnect all ribbon cables from their connectors.
