Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
How to remove and replace the monitor on the Apple Powerbook 5300
Wat je nodig hebt
Position the Powerbook towards you with the monitor closed.
Press the battery removal latch located on the right side of the front panel.
Gently slide the battery out.
Turn the laptop over and remove the three T8 torx screws from the bottom panel.
Remove side panels by pulling up and towards the rear of the laptop. Remove the two torx #8 screws.
