Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Position the Powerbook towards you with the monitor closed.
Press the battery removal latch located on the right side of the front panel.
Gently slide the battery out.
Turn the laptop over and remove the three T8 torx screws from the bottom panel.
Turn the laptop back over and open the monitor.
With the monitor facing towards you, gently pull up on the keyboard panel from the bottom.
Gently lift up the laptop's front-most panel and slowly raise the trackpad from the logic board.
Disconnect the front panel's ribbon cable from the board by slowly pulling it out of the connection port. Set the panel aside.
Unscrew the Torx #8 screws holding the hard drive case in place on the logic board.
Lift up on the hard drive to disconnect its ribbon cable from the logic board, just like in the previous steps.
Unscrew the four Torx #8 screws holding the hard drive to its case.
