Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
This repair will need:
A T8 Torx screwdriver.
Onderdelen
Geen onderdelen opgegeven.
  1. After completing the initial disassembly, you may proceed to hard drive replacement.
    • After completing the initial disassembly, you may proceed to hard drive replacement.
  2. First, you will need to remove the five T8 torx screws that mount the hard drive to the internal frame. Next, you will remove the mounting frame and the plastic shield.
    • First, you will need to remove the five T8 torx screws that mount the hard drive to the internal frame.
    • Next, you will remove the mounting frame and the plastic shield.
  3. SLA DE UPGRADE OVER
    Bespaar door het te repareren met een alles-in-één kit.
    Koop iPhone-reparatiekits
    SLA DE UPGRADE OVER
  4. You can use a spudger (tool shown in photo) to remove the ribbon cable from the hard drive.
    • You can use a spudger (tool shown in photo) to remove the ribbon cable from the hard drive.
  5. Carefully, pry the ribbon away from the pins.
    • Carefully, pry the ribbon away from the pins.
  6. Attach the ribbon cable to the new hard drive and follow steps 1-3, in reverse, to complete the installation.
    • Attach the ribbon cable to the new hard drive and follow steps 1-3, in reverse, to complete the installation.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Tyler
135 Reputatie
2 handleidingen geschreven
Cal Poly, Team 20-66, Walters Spring 2011 Lid van Cal Poly, Team 20-66, Walters Spring 2011
CPSU-WALTERS-S11S20G66
4 Leden
3 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 13
Altijd: 4,090
